There are mast tuning instructions available. Try the search function on this site.
You will need about 6" of pre-bend measured by a tight line between masthead and goose neck. Anything more than this may make the rig unstable. The pre-bend is put into the mast using the 'diamonds' and is normally done with the mast off the boat - but I see no reason why it would not be okay with the mast stepped and the shrouds not tightened.
Then tighten the shrouds and remove the additional bend caused using the lowers. This is best done progressively until the shrouds are at about 20% of breaking strain and the mast is straight athwartships.
You will also need about 6" of rake measured by a heavy tool hung on the main halyard on a calm day - and with nobody in the cockpit.
Please be aware that raising the main is hard work on these boats due, in part, to the pressure of the full length battens against the mast together with losses in the deck organizers.
I fitted ball bearing sliders on the batten pockets with little improvement so then I used a double length halyard made fast at the mast head on a shackle through a ready made hole in the fitting. I have a sheave on the head of the sail but it still needs winching the last couple of feet. Of course I can use a thinner halyard 12mm from memory and this helps too.
